Activity › Forums › Apple Final Cut Pro Legacy › changing motion attributes to every clip on timeline.
  • changing motion attributes to every clip on timeline.
    Posted by Cee Dee on January 24, 2007 at 6:22 pm
    had an assistant work on a sequence at home (gave him all the media on firewire drive). for some reason his sequence was set to ntsc when all the footage was dvcpro hd. i changed his sequence preset and all the clips are now re-scaled and “distorted”. is there a way to set every clip on the timeline to its default “motion” settings at once. thank you very much
    Cee Dee replied 19 years, 8 months ago 1 Member · 1 Reply
  • Cee Dee
    January 24, 2007 at 6:24 pm
    i should have put a bit more effort into this before posting.. select every clip on timeline ctrl click a clip and select remove attribute… 🙂 sorry
