Activity Forums DaVinci Resolve Changing lut faster
  • Changing lut faster
    Posted by Alex Gat on June 7, 2021 at 3:41 pm
    Hello,
    I have bought a set of 200 Luts that I have installed in Davinci.
    So far I set the lut for a particular clip (generally I do this on a timeline’s node) right clicking on the node > Luts > 3D lut > Myluts > and I then I pick up a lut.
    To go from one LUT to the other that way is just a nightmare. Is there a quicker way to go from one LUT to the other (once click will be good 🙂
    Michael Gissing replied 5 years, 3 months ago 2 Members · 1 Reply
  • Michael Gissing
    June 8, 2021 at 2:21 pm
    On the Color page you can open all the LUTs and display them in list mode or thumbnail. I use two screens so for me the LUTs are on the second screen at the top left. If you have a node selected you can simply go down the list and double click on a LUT and it will load into the node. I usually have my most common LUTs added into the favourite folder so it is easy to find and apply this way. I would like it if it preview applied by just using the mouse hover like many of the effects and transitions or the fonts.
