Activity › Forums › Adobe Premiere Pro › Changing Log Setting to AV
  • Changing Log Setting to AV
    Posted by Joe Wilson on September 2, 2006 at 3:09 pm
    Hi, I’m a bit new to Premiere Pro, a huge fan and supporter of Creative Cow, and I have just logged a hundred clips without noticing that I accidentally pressed “A” which makes them Audio Only.
    I can’t figure out how to get Premiere to Capture Audio AND Video without going through and logging every single clip again. Please help!
    Joe
    Roger Averdahl replied 20 years, 1 month ago 2 Members · 1 Reply
  • Roger Averdahl
    September 2, 2006 at 4:19 pm
    1. Select all logged clips and go to Project > Export Batch List
    2. Name the file and press Save
    3. Go to Project > Import Batch List
    4. Select the exported Batch List and press Open
    5. In your Project Window/Panel a new Bin with the same name as your Bacth List will be created upon import.
    6. Double click that folder to open it
    7. That Bin contains all imported logged clips and they are all set to Take Audio and Video
    8. Select the clips and press F6 to start Batch Capturing your clips!
    All “old” logged clips will be in your project and you will have to manually delete them.
    /Roger
    Premiere Pro User Group Sweden – http://www.pproug.se
