Activity › Forums › Adobe After Effects Expressions › Changing keyframe times using an expression
Ivan de Wolf replied 4 years, 2 months ago 3 Members · 11 Replies
Ivan de Wolf
July 19, 2022 at 1:45 pmHi Dan!
Thank you for this wonderful tip, but I came across a dilmna which somehow my brain is not able to solve…
I would like to do exactly the same thing, but with 2 keyframes only. So basically the value of these keyframes shouldn’t change, but the last keyframe should be able to be moved within time based on a slider. Essentially I want to smartly make an animation of a parameter longer and shorter.
I tried applying these solutions you gave but I wasn’t able to isolate the time movement of only the last keyframe.
I hope you can help with this,
thank you in advance!
Ivan
