Activity Forums Adobe After Effects Changing Hair Color From Black to a Lighter Color?
  • Changing Hair Color From Black to a Lighter Color?
    Posted by Eric Goldstein on August 29, 2006 at 11:41 pm
    I’ve got to change the color of someone’s hair from black to a lighter color and keep it looking natural.
    Any suggestions?
    Eric
    Eric Goldstein
    Giraffe Film Company
    Los Angeles
    eric@giraffefilm.com
    Levon H replied 20 years ago 4 Members · 3 Replies
  • Alexander Gao
    August 30, 2006 at 12:49 am
    This is just an idea… i really dont know that much about this… but you could try messing around with keylight and matting around the hair area… just an idea.
    Alexander Gao
    “When the revolution happens, I’ll be leading it.”
  • Andrew Kramer
    August 30, 2006 at 1:43 am
    Probably going to hand roto the hair with an adjustment layer, then using a combination of color correction tools like Hue and Sat with some curves may do the trick. However Black hair would be most difficult since there isn’t much data in the dark areas of video so lightening and coloring may look unnatural.
    Andrew
  • Levon H
    August 30, 2006 at 2:14 am
    if your going to do it frame by frame, check out the colour replacement tool in Photoshop CS1 and CS2. ive used it on hair before, but like andrew said, black is black.. and there isnt alot of luma range like you would get in blonde hair.
    my band http://www.myspace.com/counterfeittraitor
