Activity › Forums › Apple Final Cut Pro Legacy › Changing Frame-rate so I can rotoscope
  • Changing Frame-rate so I can rotoscope
    Posted by Jake Hoover on November 28, 2012 at 5:02 pm
    Hello, first time on this forum along with first time using final cut pro! My school has picked up a copy of Final Cut Pro and they’ve assigned us to do rotoscoping, if you don’t know what it is check this out. Basicly , I need to make the frame rate from 30fps, to 12, or 24 fps… Is this a possible thing to do?
    I need to do this because I need to have my 1 minute movie turned into the still frames, ex 1 minute movie at 24 frames per second would be 1440 frames, I’m sure you already understood that though.
    Any help in this area would be MUCH apreciated!
    Rafael Amador replied 13 years, 10 months ago 2 Members · 3 Replies
  • Rafael Amador
    November 28, 2012 at 5:14 pm
    Your link is a mess of explanation.
    But to make what you want, you can try this:
    – Open your clip with QT, and Export > Still Sequence.
    – Set the number of still you want (Animations traditionally used to be done with 18fps).
    – Export.
    rafael
    http://www.nagavideo.com
  • Jake Hoover
    November 28, 2012 at 5:26 pm
    I opened up quicktime and i only have three options under export, not quite sure where I should be looking.
  • Rafael Amador
    November 29, 2012 at 1:47 am
    I guess that is QTX.
    You need QT.7.
    Rafael
