Activity › Forums › Adobe After Effects Expressions › changing faces
changing faces
Posted by Quentin Block on March 5, 2007 at 8:03 pmHi-
I
Quentin Block replied 19 years, 7 months ago 2 Members · 4 Replies -
Filip Vandueren
March 5, 2007 at 9:28 pmI would precompose and sequence the frown and smile, then add a similar expression to time remapping that toggles between frame 0 and 1.
Another approach could be two layers with inverted expressions for opacity, one is visible when the other ones not.
Quentin Block
March 5, 2007 at 10:10 pmThank you. This makes sense.
I’m not sure how to create the expressions for opacity, or time remapping that toggles between frame 0 and 1.
Any suggestions?
Once I go to the pulldown menu and add an expression (on opacity for a particular layer), it just says “opacity” on the layer. I don’t know what to do after that…
I’d like to learn how to create some of these simple expressions but I don’t know the language yet…
Can you possibly give me a sample script or pointers how to do this?
Thanks so much! -
Filip Vandueren
March 5, 2007 at 10:29 pmAh, now I see it’s Mylenium’s script,
I thought you knew some basics…
anyway, a simple way for controlling the opacity would be this:
(this assumes it’s the layer’s own X-scale that needs to control it’s opacity)expression for opacity of the smile:
xscale=scale[0];
xthreshold=80;
if (xscale>xthreshold) {
100
} else {
0
}the frown layer would be exactly the same, only swap 100 and 0.
I think this expression kind of speaks for it self, one thing to note is this:
scale is an array with 2 or 3values (for x, y and possibly z) the first element in an array is called element 0 (that’s computer logic for you)
so scale[0] means the first value of the scale-array, so that’s the x-scalethe value of xthreshold should be set to the value at which you wan’t it to switch.
for timeremapping you basically need the same expression, just use 1 and 0, but mind you 1=1 second, so put the smile at 1 second, and the frown at the start of the precomp.
I would use the timeremapping: it uses fewer layers.BTW: the same thing can be written in 1 line:
scale[0]>80 ? 100 : 0;
this means exactly the same:
is scale[0] bigger than 80 ? QUESTION MARK
result=100
else: COLON
result=0;
so “A?B:C” is short for “if(A) { B } else {C }”
and if you need another layer’s scale to control the opacity, you’ll need something like:
thisComp.layer(“Audio Amplitude”).scale[0]
the pickwhip comes in very handy to ‘pick up’ references like those, you can find more info about that in the manual.
Quentin Block
March 6, 2007 at 7:40 pmFilip,
Thanks very much for your explanation and your time.
I wll try out all of this.
Cheers!
