Activity Forums Apple Final Cut Pro Legacy Changing entire sequence aspect ratio
  • Changing entire sequence aspect ratio
    Posted by Tom Hannibal on November 10, 2009 at 4:51 pm
    I’m about to play-out a sequence someone here has edited, but for some reason it has been cut into a 4×3 seqence, but the footage is all (correctly) set as 16×9. FCP has obviously letterboxed all the footage.
    Is there an easy way for me to un-letterbox the entire sequence?
    Cheers
    Tom Hannibal replied 16 years, 10 months ago 1 Member · 1 Reply
  • Tom Hannibal
    November 10, 2009 at 5:25 pm
    Never mind, I figured it out.
    Had to duplicate the sequence, made sure the new one was 16×9, then selected everything and went Right Click > Remove Attributes and selected Distort. Job done.
