Activity Forums VEGAS Pro Changing DVDA default AC3 render settings
  • Changing DVDA default AC3 render settings
    Posted by Ken Wilson on March 1, 2013 at 4:37 pm
    Greetings,
    I’m trying to figure out how to change DVDA settings for when it renders an AC3 file when I’m building DVDs from mpeg files that have embedded audio instead of separate rendered AC3 files.
    Generally I like to render the AC3 files separate in Vegas, and for those cases I change the dialog normalization level in the ‘audio service’ tab and the dynamic range compression settings in the ‘preprocessing’ tab. However sometimes I need to build the dvd from files that were not rendered with separate AC3 audio, and I want to be able to change DVDA’s internal settings to match the ones I use on my vegas render template.
    Does anyone know how to do this?
    I asked Sony’s online help system how to do it, and when they finally got back to me about it 3 weeks later they didn’t even answer my question, but instead gave me instructions on how to download the free upgrade from 5.2 to 6.0 (I originally asked how to do it in both as I am running both on different machines.)
    Ken Wilson replied 13 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
