Activity › Forums › Maxon Cinema 4D › changing default project frame rate?
  • changing default project frame rate?
    Posted by John Hammond on April 14, 2009 at 12:38 pm
    I am learning C4D, and I am in the UK so I want all my work to be at 25 FPS. I am finding that each time I open a new scene I have to go to project settings and change the fps from 30 to 25.
    I have looked around in preferences to find a way to set 25 as my default, but I can’t find anywhere to set it.
    Can it be done? Changing it manually each time is getting tedious!
    John
    John Hammond replied 17 years, 5 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    April 14, 2009 at 2:43 pm
    You can change most of Cinema’s startup settings by opening a blank scene, making the changes you want, and saving the scene as new.c4d to the directory listed at the bottom of the Preferences>Common window.
    For older versions, save the file to the Maxon root directory (directory where the Cinema executable is located).
  • John Hammond
    April 14, 2009 at 2:51 pm
    Thanks very much 🙂
