Activity Forums Adobe After Effects Changing comp (with position keyframes) size to match “new footage” size
  • Changing comp (with position keyframes) size to match “new footage” size
    Posted by Cory Christman on August 30, 2012 at 12:10 pm
    Help, I spent two days doing some work and now I have been told that the 2K footage I used has been converted to another codex (for colour correction purposes) and the size has also changed (1080 instead of 2K). Can I modify the project somehow and keep the relative positions of all the motion tracks and masks and still make it work with the HD footage or do I have to start from the beginning again.
    Cheers,
    Cory
    Kevin Reiner replied 14 years ago 3 Members · 2 Replies
  • David Chappell
    August 30, 2012 at 12:19 pm
    Can you not just drag the whole composition on to a new composition at the new size of 1080 – then scale it down to fit?
    It’s not ideal way of working but at least everything should match exact and you can then keep working on the 2k version.
    David Chappell
    Freelance Motion Graphics / 3D
    http://www.IncidentalTrees.co.uk
  • Kevin Reiner
    August 30, 2012 at 1:59 pm
    3 ways to do this.
    1. Precompose master comp into new comp at desired size.
    2. File/scripts/scale composition
    3. Change comp to desired size. Make a null and parent all layers to it. Resize down to new size.
    Mac Pro 2 x 3 GHz 6-Core Intel Xeon
    32GB Memory
    Dual-channel 4Gb Fibre Channel PCI Express card
    Dell Display (23″ flat panel)
    ATI Radeon HD 5770
    AJA Kona LSi SD/HD capture card
    Rourke 16 TB
    Flanders 2460
    SOFTWARE
    Mac OS X 10.6.5
    FCP 7
    After Effects CS5
    Boris Continuum
    Sapphire Plug Ins
    All Trapcode Plugs
    Zaxwerks Invig
