Activity Forums Adobe After Effects Changing Comp Size While Retaining Camera Framing
  • Changing Comp Size While Retaining Camera Framing
    Posted by Jonathan Reyes on February 3, 2011 at 3:03 pm
    I’m working on converting a bunch of old SD projects to HD for our network. Most of these projects use the 3d camera and a bunch of 3d layers (mainly text or vectors that can be continually rasterized). Ideally, I would just like to resize the comp to 1920 x 1080 and just give the content some breathing room, but when I resize the comp, since the camera is dependent on the comp size, everything gets messed up. Is there a way to visually keep the content the same (same framing, motion, etc) but just have the resolution and aspect ratio change? Thanks!
    Jonathan Reyes replied 15 years, 7 months ago 37,119 Members · 1 Reply
  • Jonathan Reyes
    February 3, 2011 at 3:17 pm
    nevermind, figured it out. if i mess with the zoom setting i can get fairly close to the result i’m after.
