Activity Forums Adobe Premiere Pro Changing colour within a clip in Adobe Premier Pro
  • Changing colour within a clip in Adobe Premier Pro
    Posted by Geoff Levitus on March 24, 2012 at 11:47 am
    I want to change colours within a clip, for example changing the colour of water from blue at the beginning of the clip to green at the end. Can you key this type of change, and if so, how? I am using Adobe Premier Pro CS5.
    Geoff
    Al Bergstein replied 14 years, 5 months ago 4 Members · 6 Replies
  • Todd Kopriva
    March 24, 2012 at 4:28 pm
    Yes. See this.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Geoff Levitus
    March 24, 2012 at 5:24 pm
    Thanks Todd. I did try this, but it’s very hard to make the change gradual, even with keys it jumps straight from blue to green, maybe because the colors are so close to each other. What has worked better is copying the same clip with completely changed color onto the track above and altering opacity.
  • Ann Bens
    March 25, 2012 at 12:23 pm
    Try the second color corrector in the three way color corrector.
    Adobe Certified Expert Premiere Pro
    Adobe Community Professional
  • Al Bergstein
    March 25, 2012 at 2:43 pm
    Why doesn’t key framing work with this Geoff?
    Al
  • Geoff Levitus
    March 25, 2012 at 3:07 pm
    Hi Al. Key framing does work but it’s very difficult to get a graded transition as I think that maybe the colors (blue and green) are too close. I put one key near the start of the clip in blue and a second near the end of the clip in green, hoping for a gradual change but it jumps from blue to green almost immediately.
    What has worked is putting the same clip in green on the track above the blue one and keying in an opacity change.
  • Al Bergstein
    March 25, 2012 at 3:38 pm
    Have you tried multiple keyframes along the line?
    Al
