Activity Forums Adobe InDesign changing color to greyscale
  • changing color to greyscale
    Posted by Rebecca Pentecost on December 27, 2011 at 3:05 am
    Hi
    I am very new to Indesign. Just started working with the program a month ago and it is an older version (Indesign CS2). I am designing ads for a magazine that originally were to be in color. However, they are now needing to be black and white. I did not know if there was a way to change the work I have done to greyscale?
    I cannot find any information in my indesign for dummies or just browsing on the web.
    Thanks for any advice/help I get.
    Rebecca Pentecost, DVM
    Dwayne Smith replied 14 years, 8 months ago 2 Members · 1 Reply
  • Dwayne Smith
    January 6, 2012 at 5:38 am
    G’day Rebecca
    Looks like you’re still waiting for an answer…
    There’s no easy way to do this. You can delete all your coloured swatches and replace with black — but that only gets you part way there.
    Any coloured line work and panels could be copied to Illustrator, converted to greyscale and copied back — but that’s only efficient if you’ve got a lot of it. Imported ai and eps files need to be converted in Illustrator.
    Photographic images need to be corrected in greyscale to get the best results (just a straight conversion is seldom good enough).
    Probably not the answer you were hoping for.
    Good luck with it.
    m.
