Activity Forums Maxon Cinema 4D Changing Brightness at different angles
  • Changing Brightness at different angles
    Posted by Simon Mullins on December 23, 2011 at 11:43 am
    Okay so I know that I made a thread similar to this but I’m having a similar error and using the same solution didnt work. Heres my issue.
    I have a picture as a texture for an object. But then if if I change the angles I look at the picture I see the picture with different brightness. I tried setting the picture on luminance but that didnt change it. How do I make the texture be the same no matter what angle I see it from. Is luminance still the answer and I am just setting something wrong?
    Btw Im trying to finish this video for christmas so a quick answer would be much appreciated!
    Simon Mullins replied 14 years, 8 months ago 2 Members · 4 Replies
  • Brian Jones
    December 23, 2011 at 5:57 pm
    Luminance is best for having the image look the same brightness regardless of light sources, you probably need to turn off Specular in the material.
  • Simon Mullins
    December 24, 2011 at 2:41 am
    Yeah thanks turning Specular off worked. Now this isnt really related but I don’t see the point in making a whole other thread so I’ll just post a new problem here. I have an emitter for snow except it doesnt show up when I render. How do I fix this problem? 😀
  • Brian Jones
    December 24, 2011 at 6:09 am
    that depends on the type of emitter. If it’s a standard emitter you would have to check off Show Objects if you haven’t. If it’s TP it’s bit more complex but the simplest problem would be you don’t have a Particle Geometry object. If you have that (whichever is appropriate) then I need more info…
  • Simon Mullins
    December 24, 2011 at 6:10 am
    It’s okay once I recreated the emitter and then added an object to the emmiter (a sphere) then it showed up. Thanks for your help!
