Activity Forums VEGAS Pro changing audio stream
  • changing audio stream
    Posted by Neotheone on April 15, 2006 at 4:20 am
    Hi guys,
    I was wondering if it is possible to simply change audio tracks in a video clip using Vegas without actually encoding anything? (Just substitute the original audio stream with the new one and don’t even touch original video). If it is not possible, than which program should I use?
    Thank you.
    Neotheone replied 20 years, 3 months ago 5 Members · 12 Replies
  • 12 Replies
  • Gary Kleiner
    April 15, 2006 at 5:11 am
    Not sure what you are asking, but if you change only the audio for a DV avi file then create a new avi, the new audio will be used and the video portion will be copied, but not affected in any way.
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • Ted Snow
    April 15, 2006 at 5:13 am
    Should be able to just add the 2nd audio track and mute or delete to original one without touching the video track.
  • Neotheone
    April 15, 2006 at 5:22 am
    Thanks guys. I appreciate the help.
  • Edward Troxel
    April 15, 2006 at 1:00 pm
    Another way would be to right-click the new audio, drag it to the original audio, and choose “add as take”
    Edward Troxel
    JETDV Scripts
  • Neotheone
    April 15, 2006 at 1:42 pm
    Thank you guys. I am sorry, I am new to this tool. How would I save a new project without actually touching the video? When I click “Render As”, no matter what template and codec I choose, the video is still being encoded; hence, the quality gets worse… Am I missing something?
    Thank you.
  • Edward Troxel
    April 15, 2006 at 2:34 pm
    [NeoTheOne] “When I click “Render As”, no matter what template and codec I choose, the video is still being encoded; hence, the quality gets worse”
    What format is your original video?
    What format are you rendering to?
    What FX have you added to the project?
    For example, if you start with DV-AVI, render to DV-AVI, and have made NO changes, the video is simply COPIED.
    Edward Troxel
    JETDV Scripts
  • Terje A. bergesen
    April 15, 2006 at 2:35 pm
    If you start with DV-AVI video and add a soundtrack, then render as DV-AVI with the same settings as your original video, Vegas will not re-encode your video. Naturally it will have to render, you are creating a new file with a new sound-track, but the video will be copied bit for bit as is.
    Terje A. Bergesen
  • Neotheone
    April 15, 2006 at 4:15 pm
    The clip is in WMV 9 format.
    Specifications: 720×576, 25 PAL, Pixel Aspect Ratio 1.0926.
    I am trying to change the audio stream without altering video.
    I rendered it as a WMV 9 clip with the same settings as in the original, yet, I have gotten a much larger file with playback issues- the sequence of the clips in the video is not the same as it was in the original.
    There are also no FX in this video.
    Thanks.
  • Terje A. bergesen
    April 15, 2006 at 7:27 pm
    It will re-render WMV-9. Check if the Windows Media Encoder can be used, but I doubt it. You can also try out Windows Movie Maker, but again, I doubt it.
    Terje A. Bergesen
  • Neotheone
    April 16, 2006 at 12:36 am
    Windows Media Encoder didn’t get the job done, and Windows Movie Maker is really glitchy and hangs up on me every two minutes.
    Which template and encoder would you suggest me to use in order to keep the size minimal and have an acceptable video quality? (for WMV as well as AVI files)
    I really appreciate your help.
