Activity › Forums › VEGAS Pro › Changing Audio project properties in Vegas Pro 11 will Crash and Reboot PC
Posted by Paul James chatman on March 30, 2012 at 9:25 amSince the last update to b595 changing the audio properties and pressing either Apply or OK with cause the system to reboot, every time.
This does not happen in Vegas Pro 10 b738.
As it stands all of my v11 projects must be in 48khz, 24bit, Best. Again, if I attempt to change them, even from 24bit to 16bit it will crash and reboot the system.
No dump is saved, so I do not know how to send crash data for support. I will send a help request to Sony directly as well.
Is anyone else experiencing this, if so, what was your solution?
PaulJC
hello
Paul James chatman replied 14 years, 5 months ago 3 Members · 11 Replies -
Paul James chatman
March 30, 2012 at 10:02 amThis occurs with the 16bit version as well. I am going to downgrade back to 520/521 until I get a response for a solution to this.
hello
Paul James chatman
March 30, 2012 at 10:24 amhere is the dump information:
64bit Vegas Pro –
Log Name: Application
Source: Windows Error Reporting
Date: 3/30/2012 2:07:13 AM
Event ID: 1001
Task Category: None
Level: Information
Keywords: Classic
User: N/A
Computer: PJCI-W7HP-002
Description:
Fault bucket 2809773484, type 5
Event Name: BEX64
Response: Not available
Cab Id: 0Problem signature:
P1: vegas110.exe
P2: 11.0.0.595
P3: 4f47704d
P4: StackHash_555c
P5: 0.0.0.0
P6: 00000000
P7: fffffffffffffffe
P8: c0000005
P9: 0000000000000008
P10:Attached files:
C:UsersPaul James ChatmanAppDataLocalTempWER8A20.tmp.appcompat.txt
C:UsersPaul James ChatmanAppDataLocalTempWER8AFB.tmp.WERInternalMetadata.xml
C:UsersPaul James ChatmanAppDataLocalTempWER8AFC.tmp.hdmp
C:UsersPaul James ChatmanAppDataLocalTempWERA16A.tmp.mdmpThese files may be available here:
C:UsersPaul James ChatmanAppDataLocalMicrosoftWindowsWERReportQueueAppCrash_vegas110.exe_291baeb9ea6916fb2880ee27ed3d553bbe1314dd_cab_2704a425Analysis symbol:
Rechecking for solution: 0
Report Id: ee4dbbff-7734-11e1-ad03-000272a24727
Report Status: 8
Event Xml:1001
4
0
0x8000000000000036373
Application
PJCI-W7HP-0022809773484
5
BEX64
Not available
0
vegas110.exe
11.0.0.595
4f47704d
StackHash_555c
0.0.0.0
00000000
fffffffffffffffe
c0000005
0000000000000008C:UsersPaul James ChatmanAppDataLocalTempWER8A20.tmp.appcompat.txt
C:UsersPaul James ChatmanAppDataLocalMicrosoftWindowsWERReportQueueAppCrash_vegas110.exe_291baeb9ea6916fb2880ee27ed3d553bbe1314dd_cab_2704a4250
8hello
Paul James chatman
March 30, 2012 at 10:30 amCorrections: I have discovered it only effects the altering of the sampling rate option. I have been able to change the bit rate and sample quality without a crash/reboot. The system reboot only occurs when I change the sampling rate, currently set to 48Hz.
Any ideas?
PaulJC
hello
Tom Pauncz
March 30, 2012 at 4:51 pmPaul,
This sounds very much like an audio device driver problem to me. Cannot repro here on Win7-64bit and VP build 595 (64-bit).Cheers for now,
Tom Pauncz
(30WEST MEDiA GROUP) -
Paul James chatman
March 30, 2012 at 6:25 pmThis is what I thought, too, Tom. But it only occurs with version 11 build 595 & 594. This never happened with the 520 builds. I still have version 10 still on my PC, and it doesn’t occur.
Once I finish rendering this DVD menu project, I’m going to downgrade to the 52x builds. I really do not recall this happening with those builds.
I follow up..
hello
Mark Barton
March 31, 2012 at 4:29 amI cannot reproduce this either with build 595. It applies the audio property changes without crashing. Are you sure the audio driver did not change recently. I guess you will know when you revert back to the older SVP 11 build and it is still broken.
Paul James chatman
March 31, 2012 at 8:50 amYeah it is weird. No the audio driver hasn’t been updated since installing the card last year. Hm?
hello
Mark Barton
March 31, 2012 at 6:53 pmCheck to see if you have any other software running while SVP 11 is loaded that might have exclusive access to the audio card. SVP should not crash, but maybe it did not know how to handle the response from the audio driver. Usually they say to disable Windows system sounds, since you don’t want those to wind up in your audio mix. Check for things like Skype that may be running in the background. Are you running ASIO drivers or the generic Microsoft drivers? I checked the release notes for the 595 build but did not notice anything specifically that caught my eye that would cause a problem. It could be they are initializing the card differently to change the settings, but it is not generic enough of an error to cause problems on my system. I am running the Microsoft drivers as the ASIO4All driver was not working well with my hardware. It worked for a while but then I would have problems when I switched out of SVP 11 to run other programs.
Tom Pauncz
March 31, 2012 at 7:23 pmWhen I posted above to say I couldn’t repro, I was initially using the ASIO driver that is installed with my Black Magic Design Decklink Studio 2 card.
I use the same driver for Windows sounds and have never had any issues other than it insists on 48k, 16bit.
I then tried all the other drivers that showed up options in Vegas Preferences for audio device and still had no issues.
Cheers for now,
Tom Pauncz
Paul James chatman
April 1, 2012 at 10:00 pmI’ve heavily medicated right, but I don’t write this now I’ll forget…..
I have since found out that it project related. I just created a new HD project and set it for 96hz, 24bit Best and there was crash or reboot.thanks guys
hello
