Activity › Forums › Apple Final Cut Pro Legacy › changing audio bit depth
  • changing audio bit depth
    Posted by Michael Sullivan on January 28, 2013 at 8:39 pm
    Howdy,
    I have a project with a massive amount of clips. Most have been captured at 24bits, and some at 16.
    When these are mixed in a timeline, the audio is a little out of sync and I believe this is the reason.
    Does anyone know if it’s possible for me to change the bit depth within FCP or anywhere else without changing the video information in said clip?
    If it was just a few clips I would recapture, but we’re talking a lot of clips.
    Mike
    Michael Sullivan replied 13 years, 8 months ago 1 Member · 2 Replies
  • Michael Sullivan
    January 28, 2013 at 11:38 pm
    Thanks for your reply,
    These clips are actually finished commercials for historical reel. Most of the spots are
    Mac 10.6.8
    2.2.26 GHz Quad-Core Intel Xeon
    16GB Memory
    FCP 7.0.3
    The source clips are standard def NTSC CCIR601
    Uncompressed 10bit 4 2 2
    720×486 29.97
    48kz
    and then some are 16bit and some are 24bit
    There also are some Pro Res 422HQ mixed in there as well, though not too much.
    SEQUENCE SETTINGS
    720×486 CCIR 601 NTSC (40:27)
    PAR 720×480 DV
    Field Dominance Lower(Even)
    Editing Timebase 29.97
    Compressor Apple ProRes 422HQ
    Audio Rate 48
    Audio Depth 16
    Config Stereo Downmix
    You’re right in my assumption that it was the bit depths, but I guess it could be something else as well.
    I have a KONA capture card and I’m judging sync on my computer monitors, not my video monitor.
    Do you need any other info?
  • Michael Sullivan
    January 29, 2013 at 12:45 am
    Judging sync? Are you saying that that the viewers in FCP aren’t accurate?
