Activity › Forums › Apple Final Cut Pro Legacy › Changing aspect ratio in the timeline
Posted by Andy Crowson on August 12, 2009 at 9:24 amHi guys. When I captured my footage in FCP6 I used the dv pal 48khz setting rather than the anamorphic setting that should have been used. But I read that it didn’t matter too much as when I dragged footage to the timeline, FCP6 would tell me that the settings of the footage I had shot did not match those I had used for the capture process and ask whether I wanted to change to the actual footage settings. This happened for most of the clips, but for some reason, it has not happened to all of them. I have been working on 27 short films, each with its own sequence, and now when I come to copy and paste all films into one master sequence to export, I find that there is a difference between the aspect ratios of some of sequences. Is there any way that I can change the aspect ratio once the footage is in the timeline?
Deborah Rosenberg replied 10 years, 3 months ago 7 Members · 14 Replies -
Tom Wolsky
August 12, 2009 at 9:30 amThe dialog box only appears for the first shot you edit into the sequence, not for any subsequent shots. If your material is anamorphic capture why wouldn’t you capture it using the anamorphic preset? If you didn’t make sure the anamorphic check is set for your 16:9 clips in the browser before you edit them into your DV anamorphic sequence.
You can change the sequence settings of the sequence, but if clips are already in the sequence they will then become distorted. You will have to reset their properties with remove attributes. This will change any motion effects you may have created.
All the best,
Tom
Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 4 Editing Workshop” -
Andy Crowson
August 12, 2009 at 9:37 amThe reason that I didn’t capture it using the anamorphic preset was because I didn’t know what ‘anamorphic’ meant. I was used to the nomenc;lature of Adobe premiere and was expecting to see ‘widescreen’ or ’16:9′ written somewhere.
How exactly do I do this, please? -
Tom Wolsky
August 12, 2009 at 9:44 amEdit>Remove Attributes. Depending on what your media actually is and you’ve done to it, you might have to reset the distort value. Again make sure the anamorphic check is set for your clips in the browser or item properties.
All the best,
Tom
Andy Crowson
August 12, 2009 at 10:17 amThanks for that. I’ve checked the ‘distort’ box in remove attributes, the only one that was availble to check. The clip as seen in the canvas and viewer is now squashed up into what I assume is 4:3. I have checked the ‘anamorphic’ row in the format box of Item properties. In the browser the footage is still listed as 720×576. How do I get the footage to appear as it should be in the canvas, viewer and timeline – i.e. 16:9? Do I need to delete what I have, and drag it once again into the timeline?
Oddly, of the 27 sequences I have, some have converted to 16:9 in the timeline and some haven’t…
Thanks a lot,Andy
Andy Crowson
August 12, 2009 at 10:26 am…Also, in the sequence settings dialogue box, the frame size of my footage is listed as 720 x 576, as this is what I captured it as I suppose, even though FCP6 apparently has changed the footage in some of the sequences to what it should be, i.e. 16:9. If I want to change it to SD anamorphic, there is no setting in the drop down aspect ratio box – all the 16:9 options are for HD. The aspect ratio as listed now is CCIR/DVPAL(5:4)
Thanks, Andy -
Tom Wolsky
August 12, 2009 at 10:34 amOnce again, check the clips item properties or the anamorphic browser column. If the original material is anamorphic check that anamorphic is on. Make sure this is checked on for the item properties of the clips in your sequences.
All PAL DV is 720×576 regardless of the aspect ration. Anamorphic material needs to have the anamorphic box checked. Do you not see the anamorphic 16:9 checkbox? Is it checked on for your sequences?
FCP has changed the material to adapt to the sequence you put it in. You apparently have put incorrect material into an incorrect sequence. Both have to be correct. The material itself has to have the anamorphic flag set and the sequence has to have the anamorphic flag set. The clips that have been incorrectly distorted have to be reset.
All the best,
Tom
Andy Crowson
August 12, 2009 at 10:47 amGot it, thanks Tom. There is no box in ‘Item properties’ to click on anamorphic – it only appears in the list of properties, and checking it there makes no change – It is in the sequence settings dialogue box that the check box appears, and that does indeed do the job! Thanks very much for your help.
Andy
Tom Wolsky
August 12, 2009 at 10:55 amYou need to have the check mark on in item properties for anamorphic material. Did you do that? If the sequence is correctly checked for anamorphic and your material is checked for anamorphic and the distort attributes have been reset it should work. Unless of course your material was not actually shot in anamorphic.
All the best,
Tom
Andy Crowson
August 12, 2009 at 11:12 amYes, I can see how all three processes are needed to get the footage to appear as it should – removing distort attributes, checking the anamorphic row in the item properties dialogue box AND checking the anamorphic box in the sequence settings… Many thanks. Can I just check with you that this anamorphic footage will appear on a standard widescreen tv as it does in the viewer and canvas – i.e. the full image beyond the outer box of the wireframe?
Cheers, Andy
Dennis Leppell
August 12, 2009 at 6:39 pmHi Tom, just saw this thread, and wondering why you gave the solution/process you did instead of:
1. Find a clip who’s aspect is incorrect.
2. click the motion tab in viewer, go to the aspect slider under distort settings. Make changes.
3. Copy clip, and paste attribute -> distort to all other incorrect clipsNear as I can figure, both should do the job well, though this method would be more target-specific in case he is mixing his media. Just trying to pick your brain on why you chose one over the other, perhaps I’m missing something here.
