Activity Forums Adobe After Effects Expressions Changing amount of movement (Sliders, Nulls, Trackers)
  • Changing amount of movement (Sliders, Nulls, Trackers)
    Posted by Dino Muhic on June 6, 2009 at 12:41 pm
    Hi guys,
    it’s hard to describe, but let’s try
    I have some tracked footage of some guys in front of a greenscreen. The camera is shaking really fast. I used tracking markers on the greenscreen to track the camera movement.
    Then I changed the greenscreen into a far distant sky background (you don’t see the floor in the shots).
    Now I of course have the problem of parallaxing because the sky background (with some airplane trails and so on) is moving exactly with the tracker and therefore looks like it’s just a wall a few yards away from the actors.
    So I thought about changing the amount of movement, or lets better say to reduce it so the sky doesn’t move that much with the tracking null. I don’t mean to smooth it out, because the camera movement is harsh and edgy but just to change the amount it’s moving. Let’s say the tracker moves from frame A to frame B with the amount of 100px along the x-axis, then I want to be able to change the amount using a percentual slider to let’s say 50% which would mean the sky only moves 50px from A to B.
    With this technique I also would be able to add more layers into the depth and using the percentual slider adjust it so the parallaxing looks good.
    I just don’t have the clue how to that…
    Is something like this possible?
    Would it even make sense or is my approach wrong?
    Thank you very much!
    Dino Muhic – Media Producer
    VFX – Motion Graphics – Web-Design – Or just ART
    http://www.dinomuhic.com
    Dino Muhic replied 17 years, 3 months ago 2 Members · 2 Replies
  • Darren Hardaway
    June 6, 2009 at 5:50 pm
    Well, I haven’t actually worked with markers before, but I’m pretty sure you just need the position of the markers to accomplish this.
    Come to think of it, I haven’t used a tracker either. 😛 But your basically saying move tracker from point A to point B 100 pixels only along x-axis. You also want a percentage slider. Start by holding the slider’s value with this
    temp = effect(“Slider Control”)(“Slider”)/10;
    if(temp<=0){0}; if(temp>100){100}
    If you have a set start and stop time on the timeline, this could work
    start = 1;
    end = 2;
    amount = thisComp.layer(“Null 1”).effect(“percent”).param(“Slider”);
    x = linear(time,1,2,value,value+amount);
    [x,value[1]]
    So thats saying as time approaches one sec, hold original value, and as time moves from 1 to 2 sec increase value by percentage null. Hope this helps!
  • Dino Muhic
    June 6, 2009 at 6:56 pm
    Thank you but it’s not as simple as that. What I need is a more intelligent script that uses every motion from the tracker and reduces it by the giving percentage of the slider.
    The motion tracker (which is basically just a NULL after the mocha part) has keyframes at every frame for position, rotation and scale and all of them have to be used.
