Activity › Forums › Adobe After Effects › Changing a Truck Color in a Music video…
Posted by Greg Burke on September 28, 2011 at 6:48 pmI have to change a White Truck into a Red Truck, Now I know this can be done in Photoshop Frame by Frame, but is there a better way to do it?
I wear many hats.
http://www.gregburkepost.comTudor “ted” jelescu replied 14 years, 11 months ago 4 Members · 3 Replies -
Ben G unguren
September 28, 2011 at 6:59 pmYou could use Mocha AE to track different parts of the truck, resulting in multiple rotoscoped mattes that you can use in combination with some color-correction filters… This would probably produce smoother movement than frame-by-frame painting.
FYI there is a “Change Color” filter in AE, where you can isolate a specific color range and tweak its hue/sat/etc, but for something like a white truck, my guess is it won’t work very well…..
Ben Unguren
Motion Graphics & Editing
http://www.mostlydocumentary.comSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Roland R. kahlenberg
September 28, 2011 at 7:24 pmI agree with Ben but I would also suggest that you should post a low rez version of the footage here at the COW. Seeing the footage will allow for a more definitive path for you to find a solution.
Cheers
RoRKIntensive AE & Mocha Training in Asia.
Tudor “ted” jelescu
September 28, 2011 at 8:47 pmSince you have a white truck it will be hard to change the color- since there is no color- to make it red. It’s hard to say without seeing the clip what the best way to do this is. It depends a lot on what kind of truck it is. Is it just the “box” behind the cabin – the easier situation- or the whole truck, rounded edges and all?
Tracking mattes with Mocha like it was suggested and then comping a colored solid on top and playing with blend modes may do the trick, but it would be best to post a clip for us to see.Tudor “Ted” Jelescu
Senior VFX Artist
