Activity Forums Adobe Photoshop Changing a file from 72 dpi to 300 dpi, Can any of you experts help a novice?
  • Changing a file from 72 dpi to 300 dpi, Can any of you experts help a novice?
    Posted by Jennifer on February 19, 2006 at 10:34 pm
    Hi.
    I need to make a psd file 300dpi. It is presently 72dpi. Can anyone recommend an easy way to do this or do i have to start from scratch? Thank you for your help!
    Jayse replied 20 years, 6 months ago 3 Members · 2 Replies
  • Del Holford
    February 21, 2006 at 10:44 pm
    Image>image size>change 72 to 300>enter. Is that what you need?
    Del
    fire*, smoke*, photoshopCS2
    Charlotte Public Television
  • Jayse
    March 3, 2006 at 2:41 am
    it will most likely look like heck tho – so I’d suggest recreating it from scratch at the higher resolution. Think of it as really good photoshop training to have to do it all over again. the Lesson is: don’t do it at 72dpi!
    Another thought tho – is that this could be 72dpi at 33inches big. If that’s the case – following Dels advice above, add in that you don’t want ‘resample’ turned on. This will change the dpi to 300 without loss of quality (and result in a smaller print size)
    hope that helps!
    // jayse
    Ultimate After Effects Video Training CDs
    Free Photoshop CS Video Tutorials
