Activity › Forums › Adobe Premiere Pro › Changing a clip’s timecode
Posted by Adrian Sancho on April 22, 2009 at 12:25 amHow can I change the timecode of a clip so it’s synchronized with another clip? Is there a timecode calculator in PPro?
I come from working with Avid Xpress, where you can calculate the time difference between two tracks (once you’ve visually lined them up) with a timecode calculator and then simply change the timecode of B clip to match A. It’s pretty straightforward.
Can you do this in PPro?
Adrian Sancho replied 17 years, 4 months ago 2 Members · 4 Replies -
Adrian Sancho
April 22, 2009 at 3:34 amOK, well, unless someone knows of a better way, I figured this out. First you need a timecode calculator. I googled and found this windows-based freebie:
https://www.mediachance.com/dvdlab/freetime.htm
There’s a similar widget for you Mac folk out there.
So you find your sync points on your two (or more) clips and set markers for convenience. Depending on which clip is to be your timecode source, you add or subtract your timecode from clip B to clip A. The difference will be added or subtracted (again, depending on what you want your source to be) by selecting clip B and going to FILE, TIMECODE. Change the timecode to whatever result you’ve calculated, and your two clips are now sync’d. Repeat for additional clips.
Note that with the above-listed freebie calculator, make sure you’ve changed it’s MODE setting from CONVERSION to EDITING. Otherwise you’ll have a wrong calc. Should you accidentally do this, simply redo your calc in the EDITING mode with your new timecode and you’ll wind up in the right place. I speak from experience. 🙂
Jon Barrie
April 22, 2009 at 3:40 amWhy not add the same numbered marker to the sync point of the clips add them to the timeline stacked over each other and select them right click and choose synchronise… then use the numbered marker to sync them. Done.
– Jon 😉
Or am i understanding your need to sync timecode for the wrong use?Jon Barrie
aJBprods
http://www.jonbarrie.net -
Adrian Sancho
April 22, 2009 at 3:46 amI wasn’t clear about a few things here:
>>…add or subtract your timecode from clip B to clip A<< That should be from the timecode listed on your marker points on your A and B clips. You then add or subtract, again, depending on what you want your source to be, the result calculated figure from the B clip's START timecode, as listed when you go to FILE, TIMECODE for the B clip. Your clips should now be sync'd. 🙂 -
Adrian Sancho
April 22, 2009 at 3:10 pm>>Why not add the same numbered marker to the sync point of the clips add them to the timeline stacked over each other and select them right click and choose synchronise… then use the numbered marker to sync them. Done. Or am i understanding your need to sync timecode for the wrong use? << I don't think that changes the timecode of the B clip. I want the clips permanently sync'd. I shoot multiple cameras sometimes, and I leave them running throughout. This way I just bring all the footage in and sync clips B, C, etc. to A. I only need to sync each clip just once this way. I then just need to jump to a given timecode and see if clip X has a POV that I may want to use. So the method I outlined here, which is essentially the way I used to do it in Avid Xpress, accomplishes this. I'm surprised there's no timecode calculator in Premiere, but fortunately there's plenty available to use.
