Changing a 1920×1080 HD Letterboxed video into 720×576 PAL FHA
Hey guys! This is a FCP and After Effects question, so I’m posting it in both. Apologies if this is not the correct thing to do…
I have a project which is 1920×1080, Apple Prores HQ, Square pixels, with letterboxing added. I have been asked to send a version that is 720×576 PAL FHA. Now, I did a search on here and found this thread and tried what it suggested. The only problem is that this suggests using the PAL D1/DV Widescreen preset for an After Effects comp and dropping in the video, scaling it, and rendering. Although this did look okay, it is not the dimensions I need. I need it to be 720×576. I tried changing the comp settings to 720×576 PAL with square pixels but when I tried to resize my video within these dimensions, I either lost quite a bit of frame on either side or had too much empty space above the letterboxes on top and bottom. What is the best way to resolve this? Thanks so much!
jessekirbs
