Activity Forums Apple Final Cut Pro Legacy Changing 25fps footage rendered to 30Fps back to 25fps again…
  • Changing 25fps footage rendered to 30Fps back to 25fps again…
    Posted by Adrian Kelaty on January 10, 2012 at 3:38 pm
    Hi there
    I shot a four hour wedding video at 25fps (50i) and I erroneously put it into a sequence which was set to 30fps. When I export it at 25fps, it goes horribly out of sequence. Can I reconvert it to 25fps again?
    Oh yes, and I’ve tried pasting it into a 25fps sequence. It wasn’t a good idea….
    Adrian
    Adrian Kelaty replied 14 years, 8 months ago 2 Members · 2 Replies
  • Shane Ross
    January 10, 2012 at 5:23 pm
    YOu are going to have to copy and paste into a new proper sequence, and then fix all the gaps that appear. There will be a lot of fixing to do.
    Shane
    Little Frog Post
  • Adrian Kelaty
    January 10, 2012 at 6:25 pm
    Hi Shane
    Thanks for your reply. I was fearing that would be the case!
    Oh well 🙁
    Kind regards
    Adrian
