Activity › Forums › Maxon Cinema 4D › Changes made to motion tracked camera are not saving
  • Changes made to motion tracked camera are not saving
    Posted by Petr Stovik on April 1, 2019 at 9:02 am
    Hi, I inherited C4D file ready for render, with two tracked cameras set up.
    I have both of them in the Morph camera so i can make one seamless camera motion. The second tracked camera needed some slight editing at the end so i keyframed few frames by hand.
    So far everything is working good and i rendered the video over night. My boss was really happy with the outcome, but of course he asked for some slight edits.
    So I fire up the c4d file and notice that the changes made to the second camera didn’t save for some reason.
    I tested it multiple times, and the changes to the camera just don’t stick after I save and close the application. I tried adding a simple cube just to see if it’s just the camera problem or if nothing saves, but the cube saved just fine.
    Is there something obvious I’m missing?
    I can’t imagine editing that camera the same way every time I need to re-render the file and i will have to re-render it a lot, since this is for a big, ongoing project.
    I’m using the latestR20 build with Octane renderer, if that helps.
    Thanks for any help.
    Petr Stovik replied 7 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
