Activity › Forums › Adobe After Effects Expressions › Change value when position reaches certain value
  • Change value when position reaches certain value
    Posted by Shashank Raghu on October 27, 2020 at 1:59 pm
    I want Text layer Opacity to change its value from 100 to 50 when the shape layer reaches the position x & y value between 90 and 110.
    x = transform.position[0];
    y = transform.position[1];
    a = thisComp.layer("Shape Layer 1").transform.position[0];
    b = thisComp.layer("Shape Layer 1").transform.position[1];
    z = x + y;
    c = a + b;
    if(z == c){
    50;
    } else {
    100;
    // Comp Size = 200, 200
    // x and y value = [100, 100]
    // a and b value = [100, 100]
    in this, the opacity is exactly changing when Shape Layer reaches [100, 100],
    but I want opacity to change when the shape layer position value is between [90,90] and [110, 110]
    And if the Text Layer position is [50, 50] opacity should change from 100 to 50 when the Shape Layer position value reaches + or – 10(between [40, 40] and [60, 60]) to the Text Layer position value.
    Shashank Raghu replied 5 years, 11 months ago 2 Members · 2 Replies
  • Brendon Murphy
    October 28, 2020 at 4:42 am
    try this:
    firstMin = 40;
    firstMax = 60;
    secondMin = 90;
    secondMax = 110;
    //this sets opacity rules for when text pos is [50,50]
    if (x==50 && y==50 && a>firstMin && b> firstMin && a<firstMax && b< firstMax ){
    50
    }else{
    //if text pos is not [50,50], set the opacity based on the other shape values
    if(a>secondMin && b>secondMin && a<secondMax && b<secondMax ){
    50
    } else {
    100
  • Shashank Raghu
    October 28, 2020 at 10:50 am
    It worked thanks a lot.
