Activity › Forums › Adobe After Effects Expressions › Change Value on Previous Keyframe in Index, not Nearest
  • Change Value on Previous Keyframe in Index, not Nearest
    Posted by Jonathan Moxness on July 31, 2020 at 7:04 pm
    I have an expression on a Null slider (“Magazine control”) that I want to add 25 to the value of every time I add a keyframe to another slider on the same Null (“Magazine Reload”). Currently I have it mostly working except it’s changing when it’s closer to the next keyframe than it is to the previous, and I want it to change only when it hits the next keyframe, not when it’s closer, so I need to reference the previous keyframe instead, and I’m not sure how to do that.
    Here’s my expression currently (applied to the “Magazine control” slider effect):
    reload = effect(“Magazine Reload”)(“Slider”).nearestKey(time).index;
    Math.round(value)+(25*reload);
    I found a couple other forum posts referencing previous keyframes in expressions, but I couldn’t figure out how to translate them to my problem.
    reload = effect("Magazine Reload")("Slider").nearestKey(time).index;
    Jonathan Moxness replied 6 years, 2 months ago 2 Members · 2 Replies
  • Dan Ebberts
    July 31, 2020 at 7:21 pm
    I haven’t tested it, but it should be like this:
    if (time < effect(“Magazine Reload”)(“Slider”).key(reload).time) reload–;
    Dan
  • Jonathan Moxness
    July 31, 2020 at 7:56 pm
    Thank you so much Dan! Works perfect!
