Activity › Forums › Apple Final Cut Pro Legacy › Change to 650 x 490 inside FCP?
  • Change to 650 x 490 inside FCP?
    Posted by Vincent Strader on October 31, 2007 at 8:53 pm
    Is there a way to distort the video image by only using the FCP program and no 3rd party programs? I want to make the video 650 x 490 or 630 x 470. I have motion and may try it in there, but I just thought it would be easier if I could do it right inside of FCP.
    Vinnie
    Rafael Amador replied 18 years, 11 months ago 3 Members · 2 Replies
  • Jerry Hofmann
    October 31, 2007 at 9:43 pm
    File/export/QuickTime Conversion… then select the codec of your choice and change the size to what you want.
    Jerry
  • Rafael Amador
    November 1, 2007 at 4:58 am
    If you want to get a movie 650 x 490 or 630 x 470 in FC, you only need to change the setting of your sequence and set those parameters. Them drag your clips to the time-line and change the values in “Distort” of the Motion tab.
    Rafael
