Activity Forums Adobe After Effects Expressions Change the in/out point of the work area defined by frames
  • Change the in/out point of the work area defined by frames
    Posted by Adrián Wulfrath on April 5, 2016 at 5:33 pm
    How can i Change the in/out point of the work area defined by frames????
    Here is my code and i want to change the work area in/out point depending on which of my dropdown case is selected:
    For example for myPanel.grp.groupTwo change the in/out point to 300 frames
    myPanel.grp.groupThree change the in/out point to 100 frames
    //Subpanels: (Cuando mandas a llamar con un nombre de variable a algo específico de tu UI)
    var BtnURL= myPanel.grp.groupOne.myIconButton
    var dropdown = myPanel.grp.groupOne.myDropDownList
    var curCompFrames = curComp.duration/curComp.frameDuration;
    //Add event handler for dropdown:
    dropdown.onChange = function()
    switch(dropdown.selection.text)
    case "Salida No Image":
    alert(curCompFrames);
    myPanel.grp.groupTwo.visible = true;
    myPanel.grp.groupThree.visible = false;
    break;
    case "Salida No Asterix":
    myPanel.grp.groupTwo.myStaticText.visible = false;
    myPanel.grp.groupThree.visible = true;
    break;
    default:
    break;
    Adrián Wulfrath replied 10 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
