Activity Forums Adobe After Effects Expressions Change the colour of a word in a block of text based on its length
  • Change the colour of a word in a block of text based on its length
    Posted by Nawaz Alamgir on September 27, 2018 at 11:34 am
    I have a block of text, on around 20 lines, what I am trying to do is change the colour of a word based on its length, so all words with a length of 6 (or greater than) characters are RED.
    Should be simple enough but I can’t seem to figure out an expression to call the word length in sourceText.
    Can anyone help?
    Nawaz Alamgir replied 7 years, 11 months ago 3 Members · 3 Replies
  • Dan Ebberts
    September 27, 2018 at 4:04 pm
    You could add a fill color Animator, then add an Expression Selector, set Based On to Words, and use this for the Amount expression:
    words = text.sourceText.replace(/^\s+/, "").split(/\s+/);
    if (words[textIndex-1].length >= 6 ) 100 else 0
    Dan
  • Kalleheikki Kannisto
    September 27, 2018 at 7:16 pm
    Definitely black magic. ????????
    Senior Graphic Designer
  • Nawaz Alamgir
    September 28, 2018 at 1:59 pm
    Thank you for that bit of magic. Works like a charm. You legend.
