Activity Forums Adobe After Effects Change the Color of Multiple Layers With Change to Color Effect
  • Change the Color of Multiple Layers With Change to Color Effect
    Posted by Dorian Heller on May 10, 2012 at 8:22 pm
    Hello,
    I am trying to change the value of many shape layers based on one adjustment layer which controls the main colors and a hue/saturation/lightness expression.
    Here’s what I am working with:
    Adjustment layer:
    Color A on Shape layer A is pick whipped to the “Color Control” Effect called “A Color”.
    Then I added a “Change to Color” Effect, where I want to make the global changes to all the shape layers values via Hue, Saturation and Lightness. I am assuming that once I have the expression for Hue, I can copy and paste it to Saturation and Lightness.
    Right now I have the following expression attached to the Change to Color – Hue.
    color = effect(“Change Color (Global)”)(“Hue Transform”)
    change = .2;
    convert = rgbToHsl(color) – [0, 0, 0, change];
    hslToRgb(convert);
    I really want to use expressions to do this effect and am wondering what I am doing wrong. I get the following error:
    After Effects warning: Bad method arguments: argument 1 to rgbToHsl() must be of dimension 4
    Expression disabled.
    What am I doing wrong?
    Thanks in advance.
    -Dorian
    Dorian Heller replied 14 years, 4 months ago 3 Members · 8 Replies
  • 8 Replies
  • John Cuevas
    May 10, 2012 at 8:49 pm
    I think you need to add another channel there for the alpha, that’s why you are missing a dimension.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Dorian Heller
    May 10, 2012 at 8:50 pm
    Okay, thanks! How exactly would I do that?
    Dorian
  • Cassius Marques
    May 10, 2012 at 9:06 pm
    you’re assigning to the variable “color” a 1 dimension value… and you’re passing that out to “rgbToHsl”
    It should be something like
    convert = rgbToHsl([color,0,0,0]) – [0, 0, 0, change];
    or
    convert = rgbToHsl([something,something,something,color]) – [0, 0, 0, change];
    I’m not sure what should go what to give the desired effect…
    but that’s your error there.
  • Dorian Heller
    May 10, 2012 at 9:09 pm
    Thanks for the idea, unfortunately I’m still getting an error.
    Here it is:
    After Effects warning: Bad method arguments: rgbToHsl() needs exactly 1 argument
    Dorian
  • Cassius Marques
    May 10, 2012 at 9:25 pm
    It is one argument…are you sure you wrote it right?
    You have to keep the “(” “)”
    Worked here…
  • Dorian Heller
    May 10, 2012 at 9:34 pm
    Cassius,
    You were right, I did forget the quote marks. But now, I am getting a divide by zero error, (arg)! I have changed the values from 0 to 1 and random numeric values but still to no avail:
    color = effect(“Change Color (Global)”)(“Hue Transform”);
    change = 1;
    convert = rgbToHsl(“1,.3,.6,color”) – [1,.2,.4, change];
    hslToRgb(convert);
    Thanks for all your help!
    Dorian
  • Cassius Marques
    May 10, 2012 at 9:41 pm
    I’m sorry if this is confusing…It’s kind of hard to give you the correct simple answer when i’m unsure what you’re going for…
    but you got me wrong… I didn’t mean the quote marks…I meant you have to leave your 4 dimensions [1,2,3,4] inside the parentesis…so it is only one argument…
    I copy and pasted what I wrote you before…and it returned no errors.
    Good luck.
  • Dorian Heller
    May 10, 2012 at 10:39 pm
    Hmmm… That is weird I am trying to get the shape layers Hue to be controlled by one central Hue control, based on expressions. I have the following expression:
    change = 1;
    convert = rgbToHsl(“1,2,3,4color”) – [.2, 2, 2, change];
    hslToRgb(convert);
    This one is with quotes, and I get the following error:
    After Effects warning: invalid numeric result (divide by zero?)
    Then without quotes and just “color”:
    change = .2;
    convert = rgbToHsl(color) – [0, 0, change];
    hslToRgb(convert);
    error:
    Then with just numbers:
    change = .2;
    convert = rgbToHsl(1,2,3,4) – [0, 0, change];
    hslToRgb(convert);
    So I do think it needs quotes. But I can’t seem to figure it out..
    Here is the .aep, maybe you could look at it and tell me what I am doing wrong:
    https://dl.dropbox.com/u/17788937/Test%201%20copy.aep
    Once again, thanks for all your help, I really appreciate it.
    Cheers,
    Dorian
