Activity Forums Adobe After Effects Expressions Change the color of a specific word in a sentence with expression
  • Change the color of a specific word in a sentence with expression
    Posted by Liam Campbell on December 6, 2016 at 3:46 pm
    I’m trying to change the color of specific words that are part of a larger sentence. Is there a way to “access” a string of letters in the source text to change the color of just that word?
    Liam Campbell replied 9 years, 9 months ago 2 Members · 2 Replies
  • Dan Ebberts
    December 6, 2016 at 5:49 pm
    This is a simplistic example that might get you started. Add a Fill Animator to your text layer, then add an Expression Selector, then add this expression to the Expression Selector’s Amount property:
    targetWord = “test”;
    txt = text.sourceText;
    idx = txt.indexOf(targetWord);
    if (idx > -1){
    if (textIndex > idx && textIndex <= (idx + targetWord.length)){
    100
    }else{
    0
    }else
    0
    If your text has the word “test” in it, it should be red. This has a lot of limitations though. Only the first occurrence of the word will be colored. It won’t work right if your text is multi-line. It doesn’t account for capitalization (e.g., it won’t match “Test”).
    You could certainly come up with a more robust solution, depending on your requirements.
    Dan
  • Liam Campbell
    December 6, 2016 at 7:01 pm
    Thank you for answering, could you document what some of the lines are doing for me just to help me understand a little bit more what’s going on?
