Activity Forums VEGAS Pro Change the background of clips in Vegas
  • Change the background of clips in Vegas
    Posted by Kasper Poulsen on February 19, 2011 at 9:41 am
    Hey guys.
    Ive been planning to make a space machinima with a mix of Eve and Sims 3 clips. But I came to think about how to record what should look like inside the spaceship (Which will be done in Sims 3).
    So I need a tutorial for Vegas about how to put in some outer space pics or something on the windows, to create the right scenery.
    I hope you know what I mean.
    Anyone know how to do this?
    John Rofrano replied 15 years, 6 months ago 2 Members · 1 Reply
  • John Rofrano
    February 19, 2011 at 3:39 pm
    [Kasper Poulsen] “So I need a tutorial for Vegas about how to put in some outer space pics or something on the windows, to create the right scenery.”
    You woukld need to record your machinima with a background that can be keyed out. If you could make the background green in the machinima capture, then you could use the Chroma Key plug-in to remove it. Otherwise you will have a very hard time removing the existing background to replace it with the spaceship.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
