Activity › Forums › Boris FX Particle Illusion › change the background image in Particle View
  • change the background image in Particle View
    Posted by Norberto Tso on March 12, 2008 at 7:55 am
    can i change the image.raw file to another image and size ??
    i want put a image with 800 x 600 in the background of Particle View ..
    how i do convert a jpg file to a image.raw ?? photoshop ??
    and the maximum size of image.raw ?? is 400 x 400 ?? or i can make bigger images?
    thank you.
    Norberto Tso replied 18 years, 6 months ago 2 Members · 2 Replies
  • Alan Lorence
    March 12, 2008 at 2:04 pm
    The image size can’t be changed, so even if you converted another image to RAW format and used it, if it isn’t 400×400 then it probably won’t work.
    Alan.
    http://www.wondertouch.com
  • Norberto Tso
    March 13, 2008 at 9:58 pm
    then .. this could be a request to next release of ParticleView..
    could be nice use the particleView to live perfomances..
    and change the image size is important..
