Activity › Forums › Adobe After Effects Expressions › Change text.layer duration base on word
  • Change text.layer duration base on word
    Posted by Felix Labelle on November 9, 2016 at 5:52 pm
    I’m looking for a expression or probably in this case a script that can automatically adapt the duration of a text layer base on the number of word.
    I saw an old post close to that idea but change the duration of the comp layer and not the text layer.
    var myComp = app.project.activeItem;
    var myLayer;
    var numWords = 0;
    for (var i = 1; i <= myComp.numLayers; i++){
    myLayer = myComp.layer(i);
    if (myLayer instanceof TextLayer){
    numWords += myLayer.property(“Text”).property(“Source Text”).value.toString().split(” “).length;
    myComp.duration = 2 + Math.floor(numWords/3);
    This script was write by Dan Ebberts (creative cow forum hero) in this post : https://forums.creativecow.net/thread/227/28672
    So let say that I have a comp with multiple text layer, with different number of word, I would like to be able to select the text layer and apply the script or the expression to change the duration of the layer base on 3 word a second and also put 2 sec because I have a text animation and it stop 2 sec before the end of the text layer duration.
    Looking for this kind of formula Text.layer Total Duration = (3 words/sec.)+2 sec.
    Hope someone can help me.
    Thank you !
    Felix Labelle replied 9 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
