Activity Forums Maxon Cinema 4D Change speed of offset animation along specific sections of spline
  • Change speed of offset animation along specific sections of spline
    Posted by Kory Fenton on February 25, 2018 at 12:01 am
    I have an animation with objects that drop off of a conveyor belt onto a slide and then lands on another section of conveyor belt. I’m using a cloner with multiple objects that follow along a spline and it’s being driven using the offset slider. I’m trying to see if there is a way to keep the speed consistent when they are on the conveyor belts, but change the speed with an effector (or something else) once it hits the slide so it goes faster when it drops.
    Any help would be greatly appreciated! Also, I tried uploading my file but seems to be making a separate post? I’m very new to Creative Cow 🙂 So here is dropbox link – https://www.dropbox.com/s/30h2qlzpg1qvwe0/SplineAnimation.zip?dl=0
    Steve Bentley replied 8 years, 5 months ago 2 Members · 1 Reply
  • Steve Bentley
    March 22, 2018 at 8:13 am
    Hey Kory, Not sure if you solved this – I just saw it.
    You can make some expresso nodes so that at as certain keyframe or object position the position commands switch from one procedure to another.
    You could also approach it from a character animation point of view – when a character passes an object from one hand (where that object has been following that hand for while) to the other hand where it continues to follow the new hand. Or where they set an object they have been carrying down and leave it.
