Activity Forums Adobe After Effects Expressions Change specific keyfame’s value by expression
  • Change specific keyfame’s value by expression
    Posted by Hung Nguyendac on October 1, 2018 at 8:31 am
    Hello folks. Is there any way to make expression control like this image? I know the expression can change the value if I write on Slider, but I want to find another way to make it work on another layer.
    Hung Nguyendac replied 7 years, 11 months ago 2 Members · 2 Replies
  • Dan Ebberts
    October 1, 2018 at 3:50 pm
    Something like this might work:
    s = effect("Slider Control")("Slider");
    c = effect("Checkbox Control")("Checkbox");
    val = s.value;
    if (s.numKeys > 4){
    if (c.value){
    if (time > s.key(3).time && time < s.key(4).time){
    val = linear(time,s.key(3).time,s.key(4).time,s.key(3).value,100);
    }else if (time > s.key(4).time && time < s.key(5).time){
    val = linear(time,s.key(4).time,s.key(5).time,100,s.key(5).value);
    val
    Dan
  • Hung Nguyendac
    October 2, 2018 at 1:58 am
    Thank you very much Dan, it works like a charm.
    BTW. With this expression the Opacity Property’s value will not get 100 if i don’t add the key(5), then i found another way by precomp layer and use simple If function.
