Activity › Forums › VEGAS Pro › change redner template for 4:2:2
  • change redner template for 4:2:2
    Posted by Erin O’neill on July 11, 2008 at 2:29 pm
    I am trying to create a custom template for broadcast. I have done it before, but I dont remember what I did (an the computer that was saved on recently died).
    Anyway I am trying to render as MPEG 2. I am in the custom template creater under ‘Render As’ – On the Advanced Video tab there is a box for Sample Rate: 4:2:0 (its greyed out so I cant change it). I need to render 4:2:2. I know before there was a setting I changed somewhere else that allowed me to change to 4:2:2, but I cant figure that out now.
    Any help is appreciated!! Thanks.
    Bill Ravens replied 18 years, 2 months ago 4 Members · 3 Replies
  • Mike Kujbida
    July 11, 2008 at 4:38 pm
    In the Video tab, change the “Profile” from “Main Profile” to “High Profile”.
    Then go to the Advanced Video tab and you’ll be able to switch to 4:2:2
  • Thomas Roberts
    July 11, 2008 at 5:37 pm
    Mike,
    What is the Advantage of the 4:2:2 space? Will I see a difference? Will my clients see a difference? Will this help my 4:1:1 DV video “look better?”
    Thomas
  • Bill Ravens
    July 12, 2008 at 1:56 am
    you can’t create something from nothing. you can’t get higher quality when there is no more quality to be had. the only reason you might want 4:2:2 is to improve chromakey performance
