Activity Forums Adobe After Effects Change position in a Time Remapping Loop after each loop
  • Change position in a Time Remapping Loop after each loop
    Posted by Diego Mellado on April 3, 2014 at 11:20 am
    Dear all,
    I am trying to move a fixed amount of pixels a layer after each cycle on a Time Remapping loop (loopOut(“cycle”))
    I am not sure if this is possible, but it seems that using type=”offset” can do it. I can’t find how.
    Could somebody throw some light?
    Best,
    Diego
    Diego Mellado replied 12 years, 4 months ago 2 Members · 3 Replies
  • Darby Edelen
    April 4, 2014 at 12:53 am
    Do you want the layer to jump a certain distance when a loop completes or move a distance over the life of the loop?
    Darby Edelen
  • Diego Mellado
    April 4, 2014 at 6:27 am
    Hello Darby, and thanks for your interest.
    I would like it to move once each cycle has finished.
    I were able to do it using hold keyframes in the position property and a loopOut(“offset”) expression but I would like the movement to be erratic, not always in the same direction. Is it even possible?
    Best and thanks again,
    Diego
  • Diego Mellado
    April 7, 2014 at 11:36 am
    Hi Dave,
    First of all, thanks a lot for your suggestions.
    I already considered that option. I have 150 layers looping, I just dind’t want to move them manually, that’s waht I was asking for a pseudo-random movement.
    Best,
    Diego
