Activity › Forums › Adobe After Effects › Change Paragraph Alignment for a text layer
  • Change Paragraph Alignment for a text layer
    Posted by Mateo Baldasare on December 10, 2017 at 11:56 pm
    Hi there!
    I’m working on a rig for some text layers to align them to the left, center, or right. I wonder if there is another way (apart from the Paragraph panel) to change the text alignment. So when I change the position of the layer, it’ll automatically adjust the alignment (without having to go each time to the Paragraph panel).
    Is it possible?
    Eric Santiago replied 8 years, 9 months ago 3 Members · 2 Replies
  • Kalleheikki Kannisto
    December 14, 2017 at 6:25 pm
    I guess you could make three text layers with those alignments and then use an expression to copy the source text and determine which one is shown (the one you want to show at opacity 100, others 0).
    Senior Graphic Designer
  • Eric Santiago
    December 14, 2017 at 6:52 pm
