Activity Forums Adobe After Effects Expressions Change opacity of every other frame?
  • Dan Ebberts
    April 6, 2008 at 12:46 am
    Something like this, probably:
    opacityEven = 50;
    opacityOdd = 100;
    f = timeToFrames();
    if (f%2 == 0) opacityEven else opacityOdd
    Dan
  • Cory Weiner
    April 6, 2008 at 4:44 am
    doesn’t seem to work. I am testing it with a black solid over a red solid. I clock opacity, then alt click to add the expression. it shows the opacity at the points as either 0 or 100, but the actual black solid does not go to 0% opacity?
  • Dan Ebberts
    April 6, 2008 at 5:40 am
    So you edited the expression to look like this, correct?
    opacityEven = 0;
    opacityOdd = 100;
    f = timeToFrames();
    Are you saying that as you step through the frames the opacity says it’s changing between 0 and 100, but it really isn’t?
    Dan
