Change object dimensions and maintain existing UV unwrap style
I have downloaded a model of plain box packaging. I would like to change the dimensions of the box (length, width, height) and create a UV unwrap. The downloaded model already has a good UV. When I edit the model and generate a new UV it isn’t as clean as the existing UV. How to I change the model dimensions and keep the same good UV?
