Activity Forums Square Box CatDV Change Media Path
  • Change Media Path
    Posted by Chad Gilmour on January 12, 2016 at 10:34 pm
    Maybe a stupid question, but can you change the “Media Path” of files already in CatDV?
    I know you can add entries to the “Media Search Paths” which basically has the same result. Just wondering if it’s possible or not.
    John Vaudin replied 2 years, 9 months ago 3 Members · 4 Replies
  • John Vaudin
    January 13, 2016 at 9:32 am
    Yes. In the Media menu select “Update Media Location” and navigate to the new location of the file. If you’ve moved many files, you can multi-select clips and it will try to apply the same ‘move’ to all the files it can. You can also set up a path mapping rule from old to new, but generally better to update the records to point to the right place.
  • Chad Gilmour
    January 13, 2016 at 3:05 pm
    Perfect! Exactly what I was looking for! Thank you!
  • John Friday
    December 4, 2023 at 1:06 am
    Is this say for example when you move original media files to a NEW hard drive and change the entire path? How do you handle the PROXY MEDIA that was already created and has the OLD PATH?
  • John Vaudin
    December 5, 2023 at 12:37 pm
    Yes – this would certainly be one use of this feature. In terms of proxies – CatDV uses path mapping rules to look up the proxies – so as long as the folder structure is preserved then you can usually fix the proxy lookup just by changing a single path mapping (or if you’re using CatDV Server a Media Store path).
