Activity › Forums › Adobe After Effects Expressions › Change link text layer name to Source Text
Posted by Pierre Lenfestey on August 29, 2019 at 10:07 amHi there
I can easily get the Source Text to reference the layer name, but not he opposite way around.
Is this possible?
Many thanks
Pierre Lenfestey replied 7 years ago 3 Members · 3 Replies -
Alex Printz
August 29, 2019 at 9:16 pmNot by expression. Scripts could do it.
Alex Printz
Mograph Designer -
Andrei Popa
August 30, 2019 at 8:56 amIf you create a new text layer and don’t name it, it takes as name the source text value. Is not this how AE works? Or maybe i just did not understand what you asked.
Andrei
My Envato portfolio. -
Pierre Lenfestey
August 30, 2019 at 9:33 amThanks, guys.
I thought it might be a scripts thing.
I’m importing a text document containing a subtitle transcript into Ae. I’m then using an expression to fill the Source Text of a text layer, so that the index of the layer informs the expression which line of the text file to use.
Basically I’m looking to flow subtitle text into composition from a text document by duplicating the text layer.
The down side of this is that the text layer name updates with the expression, not the text it refers to. Because I’m duplicating the text layer, leaving the layer name blank won’t really work.
I have a feeling someone here might suggest a plug-in or script for automating subtitles in Ae. If that’s the case – recommend away!
Thanks again.
