Activity › Forums › Apple Final Cut Pro Legacy › Change length AND keyframes of a clip
  • Change length AND keyframes of a clip
    Posted by Donwickedo on September 8, 2005 at 1:58 pm
    Yo dudes,
    I need to find out if there is a way to change the length of a clip and have the filter/motion keyframes follow in suit…
    I really don’t want to change each keyframe after I change the length 🙁
    Thanks a lot and all the best 🙂
    Donwickedo replied 21 years ago 2 Members · 2 Replies
  • Bouncing Account needs new email address
    September 8, 2005 at 7:23 pm
    BEFORE you change the length of the clip.
    Select (highlight) the clip (don’t double-click it).
    Hit “Apple-C” (Copy).
    Change the length of the clip.
    Hit “Option-V” (Paste Attributes)
    When dialog box opens, choose the attributes you want to transfer and make sure “Scale Attribute Times” is selected.
    This will “stretch out” the timings of the key-frames to fit the new longer clip length.
  • Donwickedo
    September 9, 2005 at 9:35 am
    Yepp, this works :-),
    thanx a lot for you replay and all the best !
