Activity Forums DVD Authoring Change from PAL to NTSC in iDVD?
  • Change from PAL to NTSC in iDVD?
    Posted by Eoin Ryan on November 20, 2008 at 4:13 am
    Hi
    I’m shooting PAL SD. Using latest version of iDVD to burn a DVD. I want to create an NTSC DVD. If I change from PAL to NTSC, iDVD says it will re-encode everything, and I click OK, and then a message pops up on screen before the burn starts, saying that I am putting PAL material on an NTSC disc. So is this the right way to change from PAL to NTSC?
    Thanks.
    Heather Martin replied 16 years, 7 months ago 2 Members · 1 Reply
  • Heather Martin
    January 19, 2010 at 12:26 am
    I have a movie made in PAL (imovie) and IDVD. Is it a matter of just changing the VIDEO MODE in IDVD to NTSC and encoding again or do I have to change the .mov files too? What should I do?
    Cheers, Heather
