Activity Forums Apple Final Cut Pro Legacy Change frame rate of MOV file
  • Change frame rate of MOV file
    Posted by Madutis on December 14, 2006 at 10:50 am
    We have a problem with the MOV files.
    We did an ingest using PictureReady in PAL and by accident the timecode track was added as NTSC framerate.
    Now I have a reference file with video and audio in separate files and Video track has a framerate attribute of 29.97 when in fact it was recorded as 25fps.
    QUESTION: Is it possible to change a frame rate setting of MOV file from 29.97 to 25 without doing any modifications to the video stream – i.e. not removing or blending unneeded frames.
    What pops into my mind is exporting to TGA’s and reimporting back. But this needs a huge amount of storage and time (I have 5 hours of material).
    Thanks a lot,
    Darius
    Rafael Amador replied 19 years, 8 months ago 3 Members · 3 Replies
  • Madutis
    December 14, 2006 at 11:34 am
    After some googling I found this easy solution:
    https://www.ambrosiasw.com/forums/index.php?showtopic=108749
    In short it is like this: create a new Cinema Tools database, open up a clip and press Conform button.
    Thanks anyways. 🙂
    Regards,
    Darius
  • Alexander Kallas
    December 14, 2006 at 12:09 pm
    Even easier,
    Change the frame-rate in QuickTime Pro.
    Cheers
    Alexander
  • Rafael Amador
    December 15, 2006 at 9:16 am
    When you play your .mov, at what seed it plays in fact?
    Rafael
