Activity Forums Adobe Premiere Pro Change Frame Rate
  • Change Frame Rate
    Posted by Ana Wiśniewska on June 7, 2015 at 5:32 pm
    Hi!
    I have a new project in Premier pro (sequence 1280×720, 25fps)
    And as I import the file (render from Cinema 4D: .mov 25fps) to Premiere Pro 5.5, it changes framerate to 30fps. Any help?
    Ana Wiśniewska replied 11 years, 3 months ago 2 Members · 2 Replies
  • Peter Diefenthaler
    June 7, 2015 at 6:49 pm
    In the Project window, right-click the footage and navigate to Modify > Interpret Footage. Then check “Assume this frame rate” and type in 25. Also double check that C4d didn’t actually render the .mov to 30fps. If you right-click the footage and select Properties, you can see the original frame rate.
    Peter Diefenthaler
    https://www.ideafirecreative.com/
  • Ana Wiśniewska
    June 7, 2015 at 7:45 pm
    Thank you!
    It works:) I checked Properties in Premiere Pro and in fact the file has 30fps, even though all Settings in Cinema 4D have 25fps. (The only way I found to solve it, is to save folder with frames as Animation from “Picture Viewer”, where is a posibility to type a value of fps)
