Activity › Forums › Adobe After Effects Expressions › Change font weight in scripting?
  • Change font weight in scripting?
    Posted by Ben Christie on November 9, 2015 at 10:13 pm
    Hi guys! (this is repost but was told it would be better received in this forum)
    I’m hoping this is something pretty simple I am overlooking, but I am trying to find how to set the font weight via script.
    Currently I have my font set up like this. But I need to choose Helvetica Neue Medium instead. Thoughts?
    fpoControl.resetCharStyle();
    fpoControl.fontSize = 51;
    fpoControl.fillColor = [0, 0, 0];
    fpoControl.font = "Helvetica Neue";
    fpoControl.text = myString;
    fpoControl.justification = ParagraphJustification.CENTER_JUSTIFY;
    fpoDocument.setValue(fpoControl);
    Syed Iqbal replied 8 years, 2 months ago 3 Members · 3 Replies
  • Dan Ebberts
    November 9, 2015 at 10:50 pm
    You may need to set the style, but the first thing to do is make sure you know the names that AE is using. Create a comp with a text layer (Layer 1) with the desired font and try this:
    var myComp = app.project.activeItem;
    var myTextLayer = myComp.layer(1);
    var mySourceText = myTextLayer.property(“ADBE Text Properties”).property(“ADBE Text Document”);
    var myTextDoc = mySourceText.value;
    alert(myTextDoc.font + ” / ” + myTextDoc.fontStyle);
    Dan
  • Ben Christie
    December 3, 2015 at 7:19 pm
    Thanks Dan!
    This worked perfectly, I was actually just using the wrong name like you thought. Sometimes it’s best to start with what you know.
    Thanks again!
    Ben
  • Syed Iqbal
    July 25, 2018 at 9:39 am
    Hi
    I just want to understand how to I write a very small script which could make the active layer’s font style property to bold. I want to assign a keyboard shortcut to my script file later on so that I can save tons of time of doing it through mouse.
    From one of Dan’s code, I tried to manipulate fontStyle property by using setValue method but it does not work.
    myTextDoc.fontStyle = myTextDoc.fontStyle.setValue(“Bold”);
    Again what I am trying is to set the font weight of text layer from Regular to Bold. Any help would be much appreciated.
